roadking wild one chubby bars fittment
When I changed out the bars on my 06 RK classic to the Chubby 508's, I had to change cables and brake lines. I took it as an opportunity to upgrade to braided, which came out looking great. I don't think there is much difference between a 2000 and 2006 so my guess is you'll have to change cables.
you will have to upgrade the cables and front brake lines with the 508's to longer ones. When I did my 2002 RKC with these bars, I ordered all the cables and front brake line from the 2003 Screaming Eagle Road King (that bike came stock with beach bars). That also got me the braided cable upgrade as well.
Attached is a picture of my bike with this upgrade. Good luck
I'm looking at the 508s, but am trying to find what cables I'll need to replace and part numbers. I would like the diamond-black cables. I appreciate the post where it was said that Screaming Eagle beach bar cables worked. If I get the HD catalog and find cables to fit a beach bar will those work? Any suggestions?
handle bar cables
When I replaced my bars with the 0575 that are 2.5 inchs longer the stock bars I could use my stock cables, But It took me awhile to find the right way to rerought the cables. they worked that way even though it didnt fell right when the bars where turn full left or full right.
So after reading the post on here about the longer harley cable and how long it took to get them I desided to due alittle reserch, What I found is that harley gets there cable from MAGNUM. went to there website and it was clear that I could get them from Magnum chepper then from Harley. So with 2.5 inchs longer bars I desided to order 3inchs over on the throtle and ideal cables and 4 inchs over on the clutch.
I had the cables 3 days after ordering them, And after I installed them and rode with them I can say they are wonderful.
So cut out the middle guy (HARLEY) and order them Magnum......
handle bar cables
So cut out the middle guy (HARLEY) and order them from Magnum......
