Might be the DUMBEST question ever so no laughing!
Might be the DUMBEST question ever!!!
So I'm leaving for a 2000'ish mile roadtrip tomorrow around noon and I'm REALLY wanting to get a new set of grips(Get-A-Grips) while I'm on the road. I know it takes around 20 minutes or so to swap em out on a '07 without the TBW setup. Is there ANY chance at all that a tech at the Harley shop would assist in swapping em out? I'm sure I could do it, I've just never messed with the throttle cables on my bike and don't wanna mess anything up since I'll be mid-trip. Thanks for any opinions you guys might have! And if it's that easy, will I just need a few Torx bits and something to cut the old grip off with??? I'm not sure I can handle the stock grips for that long of a trip!
They are easy to change out. Just follow the instructions included and you shouldn't have a problem. I think the '07 bikes still glued on the left grip, so you will need to cut it off. You might want to bring along something to sand or cut the glue that tends to stick on the bars (when I replaced them on my VRod, I had a lot of glue that I needed to sand off to get the new grip on. I've changed out the grips on all of my bikes and it is easy to do.
It's not hard but if you've never done it I wouldn't mess with it mid-trip. That's when everything gets dicey in the problem department.
You have to loosen throttle cables and then readjust. The old grips might be glued on and you would have to cut them off. Then you want a clean surface to reapply glue of some kind on the left side. Not a 20 minute job and I don't think that a dealer will help without charging.
Why don't you get up early and be at the dealer 1st thing when they open and try to get them to put you first in line.
Call ahead and tell them you are on a cross country trip. Some, but not all, dealers take extra good care of travelers. And for what it's worth, I rode cross country with the stock grips and they were fine for me. Those get a grips look pretty cool and I'm going to check them out.
Ride safe.
Ride safe.
Ride safe.
Ride safe.
Remember the glue should set for 24 hr before use. but I'd say 1 hour would be fine as long as you don't get into a situation where you have to pull on it to much, like riding the bike. If ya move it after it starts to set but is not fully cured it will never stick right and you'll have to do it again. and that is a pain. At least wait untill the end of the ride day to do the left side, that way it will have over night to cure. JM02
