PCV Cut out
PCV Cut out
It never happened before but on my last run I had two seperate incidents when the engine would just for a split second cut out.
2010 Limited w/103, Stage 1, dyno tuned, runs perfect otherwise.
Loose connection?
Water?
Fuel?
What goes on?
Loose connection?
Water?
Fuel?
What goes on?
My 08' SG did the same thing twice and here is the reason. The PC-V and the throttle by wire on these bikes have a communication problem when the bike gets shifted at full throttle very fast (speed shifting). The motor seems to hit the rev limiter and shuts the motor down. I had to stop the bike and wait a minute then the bike would start right back up. Is this what happens on your bike?
This is one of the reasons I did not put another PC-V on my new 10' RKC. I talked to numerous HD mechanics about this and all said the same thing, communication problem. The other thing was the tach not working above 5K, another communication problem on the PC-V. Yes, I know most swear by the PC-V, I swore at it. Decided to go with a SEPST w/dyno tune and have not had any problems with it, in fact this is the smoothest running motor I have ever owned. JMO
