Front brake switch ?
On my 07 Road King the front brake switch is very sensitive and has a tendency to stay on..can we stretch a spring or ?
My 06 Road King brake switch had the same problem. I loosened up the throttle housing and brake lever bracket. After adjusting the two assemblies, the brake light would finally go off. I think I had to pull apart the two assemblies so there was more room for the brake lever to release the tension on the brake switch. Then I tightened everything back up. Works great now. Hope this helps.
Thank you for the quick reply s..I had just installed a new master cylinder since the old one was all trashed from leaking fluid.So I made a shim from a piece of a coffee can lid and it will probably out last the rest of the bike..Must have been giving me trouble all along.. six months ago I had replaced the pigtail to the rear light/brake light since it had melted..
