Rear Brake Light Switch
More info to my fellow forum members, my 09 ultra classic rear brake light switch took a dump. Got it replaced, was told that this is happening on more and more bikes. Some 2011 bikes are doing the same thing. Must be a cheap manufactered part. Or maybe just a bad batch of parts. Depress your rear brake lever and check to make sure brake lights are turning on. Want everyone to be safe out there.
Same here. Some brake fluid apparantly began leaking onto the switch and it caught fire. Dealer replaced the entire system including lines and switch. All covered so it didn't cost me anything. But I'll be keeping a close eye on that switch from now on.
Mine failed back in October. Checking the brake light is part of my daily pre-flight checks. It failed during a ride. The brake light was stuck in the "on" mode. Disconnected one of the wires and tie wrapped it as not to burn it on the header pipe and went to the closest dealer and got a new one. Installed it when I got home and bled the brakes. All better now...
