What I do not like about my SG, buffeting! Help!
Old 05-01-2011 | 12:59 PM
Damascus's Avatar
Damascus
Originally Posted by knewt5
I went with the tallest shield Harley makes. I 'm not as tall as you (5'9") and have a C&C seat which lowers and pushes back as well. At 70 MPH I have a nice quiet pocket of air around my head.
The cool factor...not so much. ...
+1. I have a huge Cee Bailey shield on my Road King, and, yeah, I've gotten some comments on it.
But I've also found that while the cool guys are standing around talking about their cool bikes, I'm out riding mine!
When I point that out, that settles them down.
  #32
Old 05-01-2011 | 11:00 PM
thewholehog's Avatar
thewholehog
Originally Posted by Damascus
I got a Road King after test rides on the Street and Road Glides buffeted me to pieces. Even then, it took some trial and error to get it just right on the Road King - and just about every other bike I've ever owned.
I don't know how practical this would be, but instead of throwing the baby out with the bath water, for those Street and Road Glides owners with buffeting problems ...
Can't you just remove the fairing and convert the bike to a shied-only/Road King set up?
Or is this so much of a hassle to not make it worth it?
The problem would be the gauges in the fairing.... You would have to get a new tank with tank mounted gauges for a start and this could prove a very costly exercise.
  #33
Old 05-01-2011 | 11:02 PM
thewholehog
Originally Posted by Iceman24
SG's are notorious for "dirty air" from above (short shield) & below the fairing. Best advice I can offer is to start w/taller shield (8.5" or more), add the fork baffle and fairing wings. These three will definitely clean things up, but I also have fairing lowers (vented) which deflect alot from below. Good luck.
Iceman..... were you able to completely eliminate all of the "dirty" air from your FLHX with your set up? Or do you still get a little bit of buffeting?
  #34
Old 05-01-2011 | 11:04 PM
thewholehog
Originally Posted by mattlal
On my 2011 FLHX, I recently replaced my 8" LRS Xstream with a 10" for touring...it rids of that "classic" look, without being too obnoxious.
I am 5'10, and with the Sundowner, 10" Xstream, and 85mph...I can ride without glasses...sometimes you simply forget the clears at home. ......
Mattlal.... does this mean that you get no buffeting at all now?
  #35
Old 05-01-2011 | 11:15 PM
NEriderFLHX's Avatar
NEriderFLHX
Had the same problem with the stock shield. I got a 8.5" Klockwerks and it solved the buffeting problem. I could barely keep my sunglasses on before the switch. Now the only time I get any buffeting is with a strong crosswind (not much is gonna fix that) but not even close to as bad as before. I am 6' tall.
Good luck!
  #36
Old 05-01-2011 | 11:25 PM
steelpony5555's Avatar
steelpony5555
Hmmmm, how bout a Honda Civic....................
  #37
Old 05-01-2011 | 11:49 PM
bullet 10's Avatar
bullet 10
NEriderFLHX, can you see over the 8.5inch Klockwerks I'm 5'7" what height would I need to see over mine.
  #38
Old 12-27-2011 | 12:54 PM
joe_carrera's Avatar
joe_carrera
I had the buffeting turbulence problem as well and I was shoked how bad it was!
I started the cure by :
- a clock Werk 6,5 inches windshield = much much better, but not perfect
- a Tee triple fork ( ? ) deflector = nice piece of equipment, a small improvment.
- Chrome fork deflector = spectacular result !
The problem is solved, gone with the wind
ps: I will not recommend or endorse the black deflector, I have no idea how it performs !
  #39
Old 12-27-2011 | 06:07 PM
lp77's Avatar
lp77
Hi Joe,
I do hate the fork deflectors so I think I will never get rid of the buffeting.
Nevertheless thanks for your advice.
Ridgerunnr
05-06-2017 02:45 PM
SGLife
06-04-2016 12:13 AM
Wonderbob
06-09-2010 09:19 AM
UPSGUY
12-13-2007 03:11 PM
adamzapple
04-27-2006 11:48 AM
Quick Reply: What I do not like about my SG, buffeting! Help!
