Trouble with Kury/Truck lite passing lamps
I bought the Kury/Trucklite LED passing lamps to match my recently installed LED headlight from the same folks. This light is slightly thicker than the stock light and does not fit the aluminum retaining ring very well. I can't seem to get the trim ring to go back on all the way. I fooled around with it for quite a while and gave up and re-installed the stock lights. I also tried to install without the inner retaining ring and then the light moves around inside the housing.
Anyone already go through this and have suggestions? I do like the lights and hope there's an easy solution my pea brain wasn't able to discover.
Thanks
Thanks
Same thing happened to me. I tried twice without success. then I wrote on here like you and found many that installed without problems. i thought I would be crazy to go at it a 3rd time. It was late, I was tired and the garage was hot. What the h3ll. I thought I give it a 3rd try and prove to be a schmuck. Would you know it, went in without any problems. they are thicker and the ring barely clamps. trick is putting it on flat while the light is centered. Off axis a little would cause the lip not to catch housing. Another thought I came up with, was try the french rings since they hold inward from front.
I popped it in with an eye ball on centering the lamp. The ring is a bitch to get on. I pushed it flush then tightened. It still holds well, but looks like ***** with the lamp sticking out beyond the ring. I will be getting the frenched ring to see if it covers better. Good luck! Can't beat the light. Be seen, be alive.
plumberdoug
05-09-2013 09:21 AM
trosel238
04-09-2012 06:33 AM
