New idea
Old 04-29-2011 | 10:45 PM
fat bob bob's Avatar
fat bob bob
Default New idea
i have great ideas all the time but let me know what you think of this--the valves use push rods WHY with the tec we have now i think the push rods and timeing belts--chains ect are a thing of the past--WE HAVE SERVO MOTORS,yes very small and powerfull servos -brushless servos- wireless servos--all we need is a transmiter on the crank and a reciver in the wireless servo--there thats it--WHAT YOU THINK
Old 04-29-2011 | 10:47 PM
67wizard's Avatar
67wizard
Old 04-29-2011 | 11:03 PM
sbergerson's Avatar
sbergerson
Not a bad idea... Less moving parts, cam chain tensioner problem solved, less weight, more precise control, and easily tunable via computer. Not sure why nobody has tried it yet...
Old 04-29-2011 | 11:11 PM
TO34's Avatar
TO34
Wonders how they would react in such heat?
Old 04-29-2011 | 11:36 PM
Bill03E's Avatar
Bill03E
I thought of this long ago, and thought about how many times those servos would have to work, on fails, and you could drop a valve into a piston, but if you could get a servo that wouldn't fail after millions of cycles you would be on to something.
Old 04-30-2011 | 12:58 AM
103 sedona orange's Avatar
103 sedona orange
+ 67wizard What you been smokin????????
Old 04-30-2011 | 06:51 AM
omgtkk's Avatar
omgtkk
Formula 1 engines use actuators on their valves. I believe they are pneumatic, and those engines turn 10,000+ rpms. Of course, the only have to last for one race before the engine is torn down.
Old 04-30-2011 | 07:18 AM
DamifIknow's Avatar
DamifIknow
Why not a Solid State Electric switch controlling a Fast acting Electric Acuator? Change lift and duration of your valves with your computer.
Old 04-30-2011 | 07:22 AM
'05Train's Avatar
'05Train
Someone (Saab, I think) has been experimenting with a cam-less engine for quite some time. The thinking is that with a simple software change you can have either a fire-breathing performance motor or a mild-mannered economy motor. The cost is, of course, astronomical.
Old 04-30-2011 | 08:06 AM
Jinks's Avatar
Jinks
Lots of possibilities. Solenoid/servo operated valves that don't need springs. Valves that are entirely outside the combustion cylinder so they eliminate the possibility of valve/piston contact. Rotary valves, etc. All it takes is a good idea, time & money.
Quick Reply: New idea
