Pinging on a 2011 Ultra Limited
Old 04-28-2011, 05:37 PM
Beechnut's Avatar
Beechnut
Beechnut is offline
Default Pinging on a 2011 Ultra Limited
400 miles, completely stock. Ping consistently at 3000 rpm. Live and ride in mile high Colorado. I assume its ping as sounds like car keys dangling on gas tank up front. Part of the break in? Does it go away? Dealer says bring it in, said I may have to buy a air filter or sport tune or some crap.
Opinions?
Old 04-28-2011, 05:40 PM
user 8373900's Avatar
user 8373900
user 8373900 is offline
Screw your dealer and call Fuel Moto. It will likely be the end of your problems.
Mark
Old 04-28-2011, 05:54 PM
DocHarley's Avatar
DocHarley
DocHarley is offline
Your using high octane gas I take it?
Possible cause could be you Electronic Control Unit (ECU) and or faulty sensors. The ECU determines the mixture of air and fuel distributed to the combustion chambers based on information from several sensors (temperature, air pressure (altitude), throttle position and RPM). The ECU uses maps to determine the proper air fuel mixture. If less fuel is sent than what the engine needs then temperatures go up resulting in pre-ignition (knock or ping).
Old 04-28-2011, 07:17 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
harley will check it out try and tell u its good, then come up with a lame download.get a decent tune.
Old 04-28-2011, 07:42 PM
Lost1's Avatar
Lost1
Lost1 is offline
Had that problem with my '07 FLHTC. A set of Xied's stopped it. About a hundred bucks at Nightrider.com
Give them a call & see if they can help you.
Old 04-28-2011, 07:52 PM
Navy Mustang's Avatar
Navy Mustang
Navy Mustang is offline
I know I'm in the minority here, but with only a pair of slip ons and a K&N filter (with stock backing plate) I've never had an issue with my '09 FLHX and I have 29,000 miles on her. The bike runs flawless. No decel popping ever, no over heating (very warm, but not over heating) and nary a ping. Guess I'm lucky.
Old 04-28-2011, 08:00 PM
FLTRU4ME's Avatar
FLTRU4ME
FLTRU4ME is offline
running premium gas?
Old 04-29-2011, 03:13 AM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
My 07 did the same thing for 16,000 miles & my buddies still does the same thing & he has over 25,000. At 16,000 I had muffler,A/C & remap done which stopped it. My new bike has been great so far. I'm not doing any mods to this one. Like my buddy says "That's What the Warranty is For"!!!!!!
Old 04-29-2011, 04:08 AM
1Harleyrdr's Avatar
1Harleyrdr
1Harleyrdr is offline
I had the same noise coming from a 110, it has taperd off as mileage has went away. 3 Dealers told me "thats the noise they make"
Old 04-29-2011, 05:43 AM
smokindave's Avatar
smokindave
smokindave is offline
Continued detonation (pinging) will destroy your motor over time. Use of highest octane available and using a lower gear (don't lug the engine) will help in the short term until you decide if you need to go to a stg 1.
Quick Reply: Pinging on a 2011 Ultra Limited
