.... I am not sure if what I want will work. I keep finding sites stating that the python true duals will work on a 2011, but their website is only saying 2010. Maybe they just haven't updated it yet. But since I have the 2011 103, would that make any difference at all, or should it fit both a 96 and 103? Thanks.
Have you called or emailed them? They might bolt up, but will they work or will they adequately support your 103. You might search to find out what folks are running for primary tube diameter in the 103, it's on the fence between 1 3/4" and 1 7/8".
I went with the V&H power duals and monster ovals. They seem to have a nice low tone and don't carry the loud obnoxious blat that so many other pipes do. I've only ridden with them approx, 300 miles but so far I like them.
If the mounting points on the frame are the same on the '10 and '11 models (I'd assume that they are), then yes the pipes will work. There is no difference between a 96 and 103 as far as the external engine parts go, and the exhaust tube diameter will be fine for either as well....
Mounts on the right side of the bike and goes under the bike and comes out on the left side. Just seen a 2011 Street Glide with a pair of them on it. Only difference is that, now the front jug is piped to go under the bike.
