Replacement Horn
Old 08-14-2012, 01:52 PM
Ragtop's Avatar
Ragtop
Ragtop is offline
Received 1,013 Likes on 577 Posts
Originally Posted by Sparky73
99.99% sure the Wolo Bad Boy is the exact same horn as my Stebel. I pulled the compressor off and stuck it under my left side cover. Horn assembly then squeezes into the stock cover. It's a very tight fit but it will go in. Zip tied it in for good measure. Need a little clear tubing and a brass fitting that I expoxied into the horn assembly. Spent about $5 at Home Depot to complete the install.
sounds great, thanks for posting
Old 08-14-2012, 09:05 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
WARDSPARTSWERKS is offline
Got my WOLO BAD MAX a while back, new model with low freq like the Stebel Compact truck horn, it seperated fairly easily, and apears it will fit under the OEM horm cover, just need some time to do the install.
Old 08-14-2012, 10:48 PM
Scubadog's Avatar
Scubadog
Scubadog is offline
IMHO, there is no horn that will "plug & play" into the stock HD wiring and achieve a desired effect.
The OEM wiring was meant to fire an electric horn. For noticeable increased volume, you will need a compressor driven horn. One option is the Stebel Nautilus compressor air horn. This is an inexpensive mod (less than $50) that will sound like a pissed off 1970's Cadillac and blow your HD electric horn off the map.
The actual horn bellows will fit under the stock cowbell and the compressor can be mounted in an alternate location.
You will need to install a direct wired relay which in turn will utilize the OEM wiring and horn button to fire the compressor.
I’m sure that if you do a search here on HDF, that someone here has fully documented this simple mod.
If you can’t find the information here, then here is a link to another good “how to” with pics.
http://harleytalking.com/showthread....tilus-Air-Horn
Old 08-15-2012, 01:20 AM
Sparky73's Avatar
Sparky73
Sparky73 is offline
That's my setup. +1 on the relay....must use a relay otherwise the amperage required to drive the compressor goes all the way back through the horn switch on the handlebar.....not good!
Old 08-15-2012, 03:39 AM
jpglide's Avatar
jpglide
jpglide is offline
I picked up a mini-beast a while back. Pricey, but it's plug and play. And pretty damn loud.
Old 08-15-2012, 08:25 AM
eddie eggs's Avatar
eddie eggs
eddie eggs is offline
I put a Wolo bad boy on the V-star, it's really loud. Got it at Harbor Freight. They have a chromed version but I got the black. I put a mini beast on the SG, it's loud as well but cost a whole lot more.
Old 08-15-2012, 11:38 AM
hbsoldier3's Avatar
hbsoldier3
hbsoldier3 is offline
Originally Posted by StanfordMan
Does anyone have any experience with the Stebel Magnum Harley Replacement Horn--Electromagnetic? I found it online at BikerHiway.com. It sells for $17.95 and reportedly puts out 136 decibels. This horn fits inside the stock Harley "cowbell" horn as a true plug and play replacement. Here's a link to a picture.
http://www.bikerhiway.com/images/lar...dblack_LRG.jpg
I looked on the that website it's not there anymore
musicnbikes
02-29-2024 06:10 PM
Brick0044
12-30-2011 03:59 AM
bassnsporty
08-24-2011 12:23 AM
jose409
09-20-2007 10:08 AM
SparkyRKM
09-03-2007 09:02 PM
Quick Reply: Replacement Horn
