What can I expect from an stereo amp?
I have a 07 FLHX, with the stock HK stereo, I have upgraded my speakers to the J&M 7.25 and have the hog pod dash speakers. I would like to know if I get an amp installed what I can expect? If I have the volume set to 6 squares now and install a amp would the volume set at the same level make the volume set at 6 square sound like it is set at 7, 8, 9 or high squares? Sorry I am not a stereo guy and not sure if this makes sense. I am posting it here so anyone that has the same setup can respond.
If you install a amp it will improve the volume and clarity of your system. You want to look into different amps to make sure you get the best one for the speakers you purchased. If you have any questions our team would be happy to assist you.
http://www.rideshack.com/Stereo-and-Audio-s/368.htm
http://www.bcae1.com/gaincon2.htm
Carl
