Notices
Tires. Bias vs radial
Old 04-25-2011, 09:49 AM
strtarrow's Avatar
strtarrow
strtarrow is offline
Exclamation Tires. Bias vs radial
Just had an email flyer from Jafrum and already ordered a new EIII from Jake Wilson (cheaper) but noticed they carried a radial tire as well as a bias, although the radial was considerably more expensive. I could not however find my size in the radial, or at least one I could decipher. Following is a link to the radial so if someone could please explain the advantages of a radial and the benefits along with the sizing differences I would appreciate it. My tire size is MT90B-16.
http://www.jafrum.com/Motorcycle-Tir...ring-Rear-Tire
Old 04-25-2011, 09:57 AM
Pumba11's Avatar
Pumba11
Pumba11 is offline
Radials are for the Goldwing.
Harley's use the Bias.
Stick with the Bias.
Old 04-25-2011, 11:37 AM
Clayslayer's Avatar
Clayslayer
Clayslayer is offline
Radials behave differently. The terms "radial" and "bias" are determined by the way the belts are woven under the tread in the general construction of the tire. You cannot look at a radial and a bias tire side by side and tell which is which unless you look at the size of the tire and know how to read it.
Radial tires have belts going "across" the tire carcass, bias have belts going "around" the carcass. Horribly simplified, i know, but if you want good info just do a Google search.
Benefits of radial type tires are less deflection and sidewall flex as the tire rotates which creates less heat, as well as stronger overall construction which leads to ultimately smoother rolling, less rolling resistance, greater durability from road hazards, etc. As you flex rubber (or any other substance) it generates heat from friction. The hotter rubber gets the faster it wears. Bias tires are notorious for developing "flat spots" if left in a stationary position for a period of time. Radials do not have this problem. Radials last longer, wear more evenly, resist cupping better, are safer......
Bias type tires are cheaper to make (though generally not cheaper to buy for some reason that eludes me...) and are not seen much in the automotive industry now a days. To my knowledge the only "bias" type tires you can even buy are gigantic off road tires (think 44 inch Super Swamper), agricultural tires, historical reproduction tires for vehicle restoration, and tires to fit your state of the art Harley Davidson....
Radial tires were adopted by the automotive industry in the early 1970s and there hasn't been a bias tire mounted by an OEM since for a reason.
Given the choice if sizes are equal get the radial. Hands down.
Old 04-25-2011, 11:52 AM
honorsdaddy's Avatar
honorsdaddy
honorsdaddy is offline
Why?
Goldwing's also use gasoline. Does that bother you too?
Old 04-25-2011, 12:26 PM
strtarrow's Avatar
strtarrow
Thanks Clayslayer, couldn't have gotten a better explanation from a tire manufacturer. Still wondering about the sizing though from the web site link.
Old 04-25-2011, 07:25 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
last ime i looked the radials had low wieght rating not suitable for a bagger.
Old 04-26-2011, 02:18 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,863 Likes on 2,428 Posts
I don't take any notice of whether a tyre is bias or radial. What I read are the tyre manufacturers' recommendations for my bike. Most if not all of them offer that information. Removes all doubt, unless you are proposing to use non-stock tyres.
Old 04-26-2011, 05:43 AM
lipster's Avatar
lipster
lipster is offline
Oh my gosh.
I would never put tyres on my Harley!!
Only tires for me.
Goodness, what were you thinking?
Old 04-26-2011, 05:45 AM
grbrown's Avatar
grbrown
grbrown is offline
Talking
Originally Posted by lipster
Oh my gosh.
Only tires for me.
I never tire of spelling 'tyre' correctly!
Old 04-26-2011, 05:56 AM
troop's Avatar
troop
troop is offline
Well, I would consider a Honda GW a bagger.
2012 Honda GW weight = 904-933# GVWR = 1340#
2011 H-D FLHTCU Limited = 901# running weight GVWR= 1360# Ultra's, Classics and Road Kings are even less.
These running/GVWR loads are within 20 pounds. I'd consider radials if decent wear is there. Hell, I'm considering going to the dark side on my next rear tire change and we know what kind of controversy that starts
Quick Reply: Tires. Bias vs radial
