HD mid frame heat deflectors
I know this has been hashed over many times but I just have to comment. I bought a set of HD deflectors for my 07 Ultra. I have read what a PIA they were to install. Well I'm here to tell ya, using the instructions provided and the hardware enclosed they are impossible to install. How are supposed to tighten the upper bolt on the right side. I used long ball sockets..ground down standard allen wrenches, plus much more. NOTHING WORKED. Finally I bought a 1/4x20 stainless hex head bolt. That worked. Still a little tough but very doable. I know I'll get responses from some who were successful using the stock parts but I sure would like to know in detail how it was done.
Also I looked at all the other brands and liked the HD's the best so please no "I should have bought this or that"
The heat dosen't bother me much, on real hot days when on trips with the girlfriend I use my full sheepskin, If the heat starts to bother me in the future I'll get the leather crotch coolers, ez on an off. I have read that some people claim the HD ones drive the heat under the seat. To each their own.
+1 on the PIA. I had trouble on the right side with getting the spring clip in place and it dropped under the starter(There is no finger room above the right head). I ended up using a nut and washer. I didn't want to have the clip work its way into the belt so I took it to a dealer the next day. They found nothing so, who knows where it went.
I use the have the kuryakyn clear heat shield and still having head. When my friend got his 2011 ultra I rode it and no heat problem so I bought the HD Mid-Frame Heat deflector. I just installed mine last week and have problem installing it. I used a dremmel to cut the tool to install it and still didn't have enough space. So I both a stainless stell hex nut and it was very easy. Regarding the clip I order one but am thinking of drilling a hole just to screw it so it won't fall off. Any suggestion on the left side to secure it?
My friend has one but its a oem that came when he bought his ultra classic limited 2011 no Harley Logo so He is now thinking of buying the original with log.
