IAT Sensor
IAT Sensor
The IAT sensor is throwing the P0113 code, which probably means replace it...was in a parade and everything heated up and possible the sensor is wasted.
The question I have is can this sensor be disconnected and the bike still run properly? I know it's function is to be a choke when it's a cold motor but I can probably compensate a bit with the Power Commander V...then when I get the $$$, I can replace the sensor.
You can try and replace it. I think they are around $20+/-. If that doesn't do it, check the wiring. The IAT wiring many times is short and pulled into place. My '05 didn't cure it by replacing the sensor, heard about the wiring problems, sure enough was stretched so tight, it had broken at the bend going into the connector. Took it off and soldered in about 2 inches of wire, problem solved.
