I want my Harley back.
Old 04-23-2011 | 09:10 PM
billpedler's Avatar
billpedler
1st Gear
Default I want my Harley back.
I have a 99 Road King Classic that now has a large hole in the crankcase. Well several in fact. Now I need a new engine so am looking for one. Does anyone have any ideas on me getting an engine here in Australia or a wreck with the same motor. Is a MM 1450 and the fuel injection is different from most.
Old 04-23-2011 | 09:36 PM
scotracy's Avatar
scotracy
Bill.....have you contacted the Moco bout the remanufacture program? Go to ur local dealer and ask bout it.
Old 04-23-2011 | 09:40 PM
obwhan's Avatar
obwhan
Sleezzz Bay
Old 04-23-2011 | 10:03 PM
AlCherry's Avatar
AlCherry
I don't think Harley can reman the cases; Ummm, maybe if bill sends all of the pieces.
Old 04-23-2011 | 10:07 PM
scotracy's Avatar
scotracy
good point....time to find a wreck bike,,,
Old 04-23-2011 | 10:11 PM
Uncle Larry's Avatar
Uncle Larry
You need to have a rebuildable core to use the MoCo engine exchange program. They will not accept cracked or broken cases.
Old 04-23-2011 | 10:21 PM
j1mmy's Avatar
j1mmy
just get a set of cases..ebay or?
Old 04-24-2011 | 06:39 PM
billpedler's Avatar
billpedler
1st Gear
New cases are almost the same price as a new engine. Prolly need a wreck I'm thinkin'.
Old 04-24-2011 | 06:57 PM
AlanStansbery's Avatar
AlanStansbery
I'd see if an S&S case wouldn't work (about 1600 dollars here in the States). It'll have the Timken bearings that'll match your '99 crank. That--and everything else--ought to swap fine from your current engine. Replace what makes sense to replace, reuse everything else. You'll wind up with a new engine for (hopefully) around 3 grand USD. Research this to make sure I'm not blowing sunshine, but I think it's doable... Then again, I'm not sure what the premium is there in Oz for parts shipped from the US.
Old 04-24-2011 | 10:06 PM
mtclassic's Avatar
mtclassic
last time I checked I found cases were not near as expensive as I keep hearing they are. You do need to return your old cases tho.
msafrit
03-11-2016 10:46 AM
jathy
05-12-2012 12:25 PM
fuzzymcnab
05-25-2011 03:16 AM
filtrod
12-02-2007 10:13 PM
Quick Reply: I want my Harley back.
