TTS MasterTune Map needed
Anyone have a map for TTS MasterTune 2010 DBW'
107" Revolution Performance
GMR stage III CNC heads
1.9 intake valves, 1.625 ex set up for 54 cam
10.2:1 compression
Andrews H54 cam (.555)
V&H Hi-output header pipes
Just completed 500 miles on engine (base 103 HO map) and before I start with Vtune, was wondering if anyone has already dialed this in?
10.2:1 compression
Your build is almost identical to mine. I also started with the 103 HO map with the displacement constant set to 106.6ci. Are you running the new MT8 version of the map? I am and have the cam specs set to 3 IVO and 3 IVC with the 54H cams. The bike runs real good as is. I'll be starting the vtuning as soon as I get a day off that's not raining. So, no I can't help with a better map but we can certainly compare tuning notes.
msr082881
02-20-2015 04:28 PM
dochawken
03-26-2014 09:09 AM
skully1200
08-06-2011 03:52 PM
