Help! 08 FLHX clutch cable change
So I have put 14 inch bars on my bike, internally wired everything, gotten nice chrome cables, almost have everything done and BAM! I have no clue how to get the old clutch cable out. I have removed it from the old clutch lever and handlebars, but I can not figure out how to get it out of the transmission itself??
I have a silver cover (where the cable screws into) which is held on by six Allen key bolts (size 3/16) or I have the back cover behind that (black) which is held in by eight allen bolts (size 1/4). All of which is covered by exhaust piping. I'm almost done and need someone who has done this before to get me through this last part?????
2008 FLHX Street Glide
Collapse the adjuster on the cable, remove the cover the cable screws into, remove the ball & ramp snap ring inside the cover, unhook cable end, unscrew the cover off the cable, Replace in reverse order. Buy service manual Lol couldn't resist. Welcome to the forum
Got to take the 6 bolts out of the silver cover. May have to loosen the exhaust to get to the bottom 2. Inside the cover you will see where the cable attaches to the arm that works the clutch rod. May have to remove the snap-ring to get the cable disconnected from the arm. Don't loose the 3 ***** that are hiding under the arm. Cable then unscrews from the cover
justmealwatts
03-27-2020 09:00 AM
ricks 2004 fatboy
01-05-2010 12:47 AM
