What motorcycle jack do you use?
#43
RE: What motorcycle jack do you use?
J & S jacks of Wrightstown, Wi. Saw one at a bike show and was suitably impressed. Rolled it under, no straps needed and a one man operation. They demonstrated on an Electraglide and climbed all over the bike when on the lift. Many cheaper lifts will do just fine but I'd consider changing out all the bolts to Grade 8.
#45
Here's what I use. Inexpensive, solid, works great, easy to use!
http://cgi.ebay.com/ebaymotors/SCISS...43523245QQrdZ1
#48
Stay away from the Sears "red" jack. The bottle jack is a major weak leak and it is not replaceable. I had a VTX 1800, about 750lbs, get stuck in the air. The jack would not lift off the safety locks. I had to take another bottle jack and lift the M/C jack high enough to get the saftey locks disengaged. The internals of the bottle jack fail and you can't pump it fast enough to make it lift. The Sears jack only has a 1 year waranty. So, I am in the market for a replacement. Would love a table lift but it takes up to much space.
