Touring pack power inverter
i had a freightliner truck,the inverter ran a microwave,fridge/freezer,laptop,and cellphone..fridge would kill the 7 batterys in 3-4 hours thou.would run it all day then turn it off to sleep..just leaving the inverter on would kill the batts in 3-4 days sitting..the rear atep bumper was rusted,between loads, i stripped it in a walmart parking lot with an angle grinder running off the inverter..then painted it in a TA truckstop in guolph ont. the next day..they wanted me to waste a day off at home to do it..
52 amps, are you serious? Come on, it's going to pull 5-6 amps max. The biggest breaker in your fuse box at home (besides the AC) is most likely 20 amps, so how do you use your 52 amp coffee pot at home? A coffee pot pulling 52 amps would be using close to 6000 watts.
I'm not saying to use an inverter on your bike, but it is possible to run one, and the coffee pot would not be out of the question.
Amps = watts/volts
These numbers below are averages. I dont think ive seen those mini inverters over 400watts. Anyone know what size charging system. Been readin a little and im finding 38 and 45 amp charging system on Harleys. Maybe it will say in my shop manual.
Quoting this from another forum:
" At 45 amps you should have a nominal 540 watts of available capacity to run all your goodies, roughly.
You should be able to find out how many watts each device requires...
45 generator amps x 12 system volts = 540 watts"
Ive read at least 700 to run a coffee maker.
Found this on the net, not for my bike but..... 29999-97B ALTERNATOR UPGRADE KIT, 45 AMP/ROTOR at Surdyke
Im also just kickin this around, thinkin out loud.
The inverter would only be used when the bike is running.
Computer System 200 watts
Microwave Oven 1200 watts
Power Drill 400 watts
Large Vacuum 1200 watts
Coffee Maker 900 watts
Circular Saw 1500 watts
Toaster 800 wattsMicrowave Oven 1200 watts
Blender/ Juicer 1000
