ECU is Dead
If thats the case, would that not mean that any ECM that had prior downloads or aftermarket tuners should be re-flashed to stock before RP can do their thing? Or would it be something specific to the TTS?
That's a very good question. I hope RP had the foresight to know this might be an issue. If they start having problems like this with the EMS compounded with the problems they had with their cylinders and pistons, they may be in deep doo doo. I bet they spent a boat load of money coming up with the EMS.
I know the file in the ECM is my TTS file. When I originally dyno tuned the bike, the tuner sold me Direct Link and he was not able to backup the original calibration file so it is lost. I have since purchased TTS Mastertune until I did the 107 build, which I've been trying to tune with TTS and have spent a week riding around with a laptop.
The file on the bike is TTS and I believe MT8, since the TTS software was upgraded last month with a new revision that produced MT8 files.
I have since emailed RP on what I believe that the problem is and I do not, at this time, think the ECM is dead, just that they cannot communicate to it. Guess I'll find out tomorrow when I talk with them.
What worries me that if anyone else that has a race tuner or TTS sends their ECM for this procedure are they going to be at the same crossroad as I am?
My case in point, exactly. If they didnt have the foresight to see that this may be an issue and spent the kind of money they probably spent developing the EMS, their company needs some serious restructuring, if it survives.
Better call TTS if it's a MT8, HD can't read or write to it. You could also try posting your problem on the HarleyTechtalk forums in the
AFR section.
ECM. Only a TTS married to the ECM has any chance of reversing the process.
RP simply needs to be sure no one sends an ECM with a MT8 loaded to them.
So maps from other tuners like Power Commander, SERT, SEST, SEPST, ect, ect wont be a problem for rev perf?
The best I could do is load the file from the dyno tune that I backed up when I bought TTS. I'm assuming the file that was created with Direct Link is not a MT8 file.
Yep you can't flash over a TTS MT8 file or even a MT7 file (since ver 1.61) with other tuning devices. Even the SEPST comes up with a "stop reflash" error and says to retry.
Only way is to put back the original MTE file but you didn't make one.
I know ways around that but I am in Australia so no help to you.
