ECU is Dead
Was the TTS hooked up to the ECM and programmed for the 107? If so do you have the files? If the answer to these are yes, then just put the files back in the ECM and hook it back up, then you will know if it works or not.
Why you would want to change fromm the TTS to another tuner is beyond me, but I'm sure you have your reasons.
The statement they give you would not satisfy me, an algorithm is the calculation the ECM does with all the input it has, to then produce the output to the pins. The problem I have with the explanation is, does the ECM accept the flash? If it does, are they saying that the parameters they set in the ECM are producing a different output at the pins, then it should? Or are they saying they can set some parameters and not others? Or are they saying that they can not flash the unit at all, they get the reply, unsuccesful from the flash?
The statement they give you would not satisfy me, an algorithm is the calculation the ECM does with all the input it has, to then produce the output to the pins. The problem I have with the explanation is, does the ECM accept the flash? If it does, are they saying that the parameters they set in the ECM are producing a different output at the pins, then it should? Or are they saying they can set some parameters and not others? Or are they saying that they cank not flash the unit at all, they get the reply, unsuccesful from the flash?
I guess I was lured by snake oil that I could install the system for any build and then not have to ride around with a laptop to get it close and it would be 5% of a professional dyno tune. I have read many reviews prior to the purchase and all were raving about it.
RP said they were unsure if the ecm would work again, so won't know till they send it back to me.
TTS uses different ECU code. Again, to repost what Copyless said, if that is the same ECU you tuned with Mastertune, you have to reload the original calibration on it with Mastertune before you send it to Rev Performance. They probably expect to see OEM files on the ECU, and when they don't see them they can't reflash as they don't know what base to start with. My guess, anyway...
QUOTE=TexasVet;8211753]I wish I could answer all your questions, all I was told is that the algorithm was not correct and could not be flashed.
RP said they were unsure if the ecm would work again, so won't know till they send it back to me.[/QUOTE]
Please keep us posted as to how this turns out,,, I have been thinking about getting one but now not so sure,, I have a 09 Ultra with SE 255 Cams as of now I had the Dealer install the SE 103 Stage II Download as a tune,, The bike runs well with this set up but thought it might get the max going with the unit you went with..
why? he did not use Jamie.
I believe that if it has a tts file still loaded in the ecm that is the problem. I bet reflashing/reloading the orginal cal will be what needs to be done so rev perf can do their magic.
Gotcha. It wouldn't hurt to see if you'll be able to reflash it with your old TTS calibration. If that works, you can try having the dealer flashing a stock cal for an '08 on it for you. If you can't restore your last TTS calibration on it when you get it back, I'd be really worried the dealer can't reflash it either.
