Best Mild-Mannered Cam for 2011 103" Street Glide?
What would be the best mild-mannered, street-able cam for my 2011 103" Street Glide?
In addition to the cam, I'll be doing a HD Stage I intake & Rinehart 4" slip-ons.
I do about 80% solo riding.
I'm looking for a cam that's just a notch above stock. Something that's quiet and idles nicely.
What cam would Harley have used on stock bikes, if they were allowed by the EPA?
Thanks
Thanks
Thanks
Thanks
I would also vote for the SE255's based on my experience with them in the TC96, but the factory 103 has a bit more compression than TC96's and coupled with 7 CI more displacement would work well with a few other cams without a compression increase. Included in this group would be the Andrews 48 (similar to SE255), Wood 555, and SE204. OTOH if low-end and midrange power are your priority and you want a bolt-in cam, the SE255 or Andrews 48 would probably maximize your satisfaction. You can pick-up low-mileage used SE255's on Ebay (mostly CVO pulls) for about $150, which IMO makes them the bargain of the group.
I put Andrews 26H Cams in. I also went with a 103" displacement but used KB Pistons which give me 0.5 more compression ratio (than the MoCo kit) and also used an MLS head gasket (Cometic) for a even just a tad more compression and a better quench area. I am exceedingly pleased with this set up. It is very smooth and pulls hard right from the word go. Carries 2nd gear up to 60 MPH and is still pulling really damn hard when I run out of courage and shift into 3rd. Can also accelerate from 50 MPH in 6th, two up with no complaints from the engine.
