slipon's and duals
Old 04-21-2011, 06:14 PM
hover's Avatar
hover
hover is offline
I ran the Monster Ovals without anything and it ran ok, except for the odd time it would ping a little and run a fair bit hotter. I added the Dresser Duals and Power vision w/ SE A/C. I guess it should run much better now.
Old 04-21-2011, 06:15 PM
Toypuller's Avatar
Toypuller
Toypuller is online now
Received 5,291 Likes on 1,584 Posts
Mufflers only is fine.
But changing the head pipe opens the flow up. I'm no expert but, the base tune on the bike has to take into account the constriction of the cat. converter.
Just removing the cat has to increase air flow significantly.
Old 04-21-2011, 07:09 PM
OldPhat's Avatar
OldPhat
OldPhat is offline
With No cat converter there is more volume of air that can go through pipes and mufflers
aftermarket air cleaner even more air will flow through the engine, making a lean condition
from the factory more lean. If there are no other engine modifications the lease you will
need is a down load, to fatten the lean condition. That being said, your best bet is do
some type of tuner, with a good dyno tune to get the best all around performance. Do it
Old 04-22-2011, 07:08 AM
kdfoster's Avatar
kdfoster
kdfoster is offline
If I opt for just slip on's now until I can do more, will the heat from the cat discolor the new slip on's? The V/H monster rounds state their blueproof, but I don't know how accurate that is. Thanks again for the help.
Old 04-22-2011, 08:40 AM
FLHTCU Owner's Avatar
FLHTCU Owner
FLHTCU Owner is offline
Originally Posted by kdfoster
I have a 2011 ultra that I want to install V/H monster rounds and dresser duals on. Do you have to get an A/C and remap if I do this? I know you don't with just the slipon's, but I'm unsure with the dresser duals. Thanks
Maybe. Personally, I would do it anyway and be done with it.
Old 04-23-2011, 03:54 AM
mike5511's Avatar
mike5511
mike5511 is offline
Save your money till you can do right and then be done with it. And no, the V&H will not blue..................its gauranteed!
Old 04-23-2011, 09:05 PM
Tek74's Avatar
Tek74
Tek74 is offline
cubbieblu
03-10-2012 07:50 PM
mjaw
09-04-2011 11:56 AM
HighLiner
07-05-2011 07:59 PM
Rubbit
07-16-2009 07:35 AM
Big Pa
Exhaust System Topics
01-05-2008 10:45 AM
Quick Reply: slipon's and duals
