internal handle bar wiring
Could anyone help me. I will be getting parts back from my painter soon. I am getting the bars painted too. I thought there was a thread here somewhere that shows how to remove the pins from the duestch (spelling) connector, and the home made tool to do so as well. I want to go this way instead of cutting and soldering. I have a 2000 Road Glide. If anyone knows of this thread, could could please enlighten me. Much Appreciated.
Its not that hard I use a sewing needle when i do mine. Take the gate loose at the rear of the connector you stick the needle into the front of the connector where the small round hole is above the connector slot and lift the little tab up, hold the small tab up and slide the connector out works great.
You don't need any "special tools" to remove/install pins/sockets into Deutsch Connectors. Just got done re-wiring my bike with them. Here's how:
http://www.deutschconnector.com/tech...ser_guide.html
Pretty good detailed pics and advice on the connectors in this thread:
http://www.roadglide.org/showthread.php?t=5694
(you're a fugly owner ... you NEED to join RoadGlide.org!)
