Using a Harley Headset while riding a non-Harley
I searched, and didn't find any info. I want to use my helmet with the Harley headset installed to listen to my ipod while riding my KLR650. Is this possible? I would need an adapter that plugs into the headset with a 3.5mm plug on the other end. I have found adapters that can be plugged into the audio system on the Harley, but not into the headset. Does the Harley headset require a power source, and therefore can not be used in this manner?
Thx
Thx
If you just want to listen you will not need a power source other than the MP3 player. I know J&M makes a cable that goes from thier headset to the Harley headset. They may be a good place to start to look for the adapter you are looking for. If not ask the Harley parts people. They probably deal with that a lot for people who want to do the same thing on a bike like a Road King that does not have a stereo.
It's not clear to me that an iPod has enough power to supply the headset (I'd be glad to find out that I'm wrong on this one). What I wound up doing in this situation was to buy this device
http://jmcorp.com/SeeProducts.asp?PF=29
and then use the adapter cable to convert its audio output to the 7-pin cable to my headset. The obvious problem with it is that it's bulky and you either have to recharge batteries (or buy new ones) or hook it up to the motorcycle's power.
Good luck and please post a solution if you find a good one.
Were you able to make the J&M Integrator work successfully with a Harley headset?
No..the headset does not require a power source.. they are just speakers.. 8 ohm.. you can fabricate a cord easily. a length of 7 or 8 conductor cable.. an inline 7 pin female DIN plug.. and a 3.5 mm stereo plug.. Since you wont be using the mic element 3 or 4 conductor cable should even work..
