Kuryakyn Driving Lights
Wanting to know if anyone has wired the driving lights for a 2011 road glide ultra to the aux plug. The instructions want you to use the supplied toggle switch, which I would rather not do. Any help in this area would be very much appreciated.
There the model number 5007
There are a few guys thats have . Here is a video of sifularson's bike he has them wired that way. He is usually in this forum.
http://www.youtube.com/watch?v=PcZ1qMUAAgk
I know the wire goes under the gauges and then to under the seat, so the best place to splice would be there. I am looking at doing the same thing but just not sure yet if I like the look or not.
I put them on my '09.
I didn't like the idea of the switch that came with the kit too. So I moved the Speedometer reset switch and enlarge the hole to fit a factory Spotlight switch. But instead of the Factory switch, is used a Kuryakyn Double switch. One for the lights and the other side for LEDs I will add later.
A buddy of mines installed these same lights on my SG and pre-warned me early on about the supplied switch and went ahead and ordered the SPOT light switch from HD. I'm going to use my ACC switch as an option to turn off a secondary AMP or possibly a module for heated vests. Good luck and keep us posted with what you finally come up with.
Do you remember what part number you used?? Did you replace the ACC switch or did you mount it somewhere else?
Thanks
I wired that light kit to the ACC switch on my 09 SG. There are pics somewhere on my profile. It worked out well. The switch of course is already powered.. just probe to find the right wires coming off the switch and splice in.
Its funny that Kuryakyn comes with the switch but if you go to their website and look, there is a video of the installation of these lights.. in that video their own bike tech. uses the ACC switch on the bike... take a look for that video... let me know if it helps...
