A word of warning for 2010 Touring Bikes
04-14-2011 | 07:49 PM
Forum rules prohibit me from posting where to find them, that means it's on another competing Harley tech forum, some of you will figure out where from my hint. And to the guy from Favre's hometown, that aint it.
04-14-2011 | 07:53 PM
my 08 RG did this on a regular basis -- have not had the problem on my 09 --
04-14-2011 | 07:57 PM
I think that mine did that once. It died at a stop light, but fired right up.
Kinda wierd..
04-14-2011 | 08:00 PM
Guess I better do some checking next time the seat is off.
04-14-2011 | 08:03 PM
These guys(internet brands) probably own the other site. Post it.
04-14-2011 | 08:09 PM
Quote:
Originally Posted by
IAMSWUTIAMS
They don't, and if I found it you can too! If you get what i'm Talk,ing about as far as a Harley Tech forum goes.org
04-14-2011 | 08:13 PM
I used dielectric grease on the ECM pins when I added the Fuelpak. I would assume this should prevent any pin corrosion.
04-14-2011 | 08:16 PM
Oh, I get it wink wink.
qtrracer
10350
Also do the same at the TB connector as HD believes that is where the problem is , not at the ECM.
04-14-2011 | 11:53 PM
Is it corrosion or loose pins? Also, is it happening with/without a PC-V? If it is just corrosion, can we just clean her up and put some di-electric grease in the connector to keep moisture out?
