A word of warning for 2010 Touring Bikes
Old 05-15-2011 | 05:31 AM
Swamphunter's Avatar
Swamphunter
I wonder why so many JapCrap lovers buy Harley's if they assume or expect they wont be happy...
  #122
Old 05-15-2011 | 10:59 AM
tenn.vol.'s Avatar
tenn.vol.
I have always said, if you buy a jap bike you put a harley mech. out of business.
And we need to keep all the jobs we can on shore! Tenn.Vol.
  #123
Old 05-15-2011 | 08:49 PM
byersmtrco's Avatar
byersmtrco
YEP!!! Amen to that !!! Even if some (most) parts are made overseas,
it's simple high school economics; BUY AMERICAN !!!
Take all these Toyota Prius' and Honda Aaacord's and Lexus'
and Goldwings and yamaha ha's and all the rest & blow em back to
J-frickin-pan !!!!
  #124
Old 05-15-2011 | 09:19 PM
Ron "Gunner" Retzlaff's Avatar
Originally Posted by hardwork2
I have 17k on mine no problems yet. I wonder ift it has anything to do with the OEM ECM. I put the SEST on right out of the box. Just curious?
I hope the OEM ECM isn't the problem because I have 16,000 miles on my 2010 Road King Classic and she is bone stock as far as power goes.
  #125
Old 05-16-2011 | 12:29 AM
KahunaJim's Avatar
KahunaJim
Originally Posted by Rattler77
If you have an 09 Ultra go get it corrected now. I went through this. I think that HD knows about the problem but a recall is way to obvious. If you don't want to take it in get some alcohol (not for drinking) and clean the ECM contact both male and female and the injector connectors and for that matter anything else. Use some dielectric grease on the connections when you reconnect. Problem is solved. I just went after my deal. Acted like I was nuts, told them to look it up I was sure a TSB or equiv out there. Thanks to this forum I had ammunition when I took it in. I had to disconnect and reconnect the ECM on the road, Thankfully it did not happen the morning of the 27th in North Alabama when we headed out in that mess for Thunder Beach. Happened the next morning. 17K on it..
My '11 did it with 1100 miles on the clock....the dealer knew exactly what I was talking about when I called and took it in. They checked it out, everything was tight they put dialectic grease and said they hoped it fixed it, it had fixed a lot of them but they thought the problem was fixed..mine was the first '11 they had seen do it. Then it happened to a guy on here on a demo ride, that bike had 62 miles on it.
My Harley dealer said the MOCO had a fix but since my showed no codes they couldn't replace any parts. They said it had something to do with the ECM ports....hopefully mines fixed but with the frickin' rain I've only been able to ride it 300 miles since I got it worked on
  #126
Old 05-16-2011 | 06:41 AM
Rattler77's Avatar
Rattler77
It is the corrosion setting up between the male and female contacts at the connector interfaces. Soon as I can get my wife to go through HER filing system I will note what the service information stated aside from cleaning and applying dielectric grease to the connections.
  #127
Old 05-16-2011 | 06:49 AM
Rattler77's Avatar
Rattler77
  #128
Old 05-16-2011 | 08:28 AM
Port Dawg's Avatar
Port Dawg
Hmmm bringing my bike in for 1k service. Wonder if dealer will look at this if I ask? No symptoms yet other than it seems to be taking a couple of secs longer to crank when cold?
  #129
Old 05-17-2011 | 06:39 AM
Rattler77's Avatar
Rattler77
Well if you don't have the symptoms you may want to wait until your next scheduled service or you might mention that you've heard about a problem and see what they do.
SBates08
04-22-2015 04:20 PM
DEGRider
07-13-2012 06:02 PM
Ditcher8
07-20-2010 04:59 PM
monza66mo
06-27-2010 08:09 PM
hoethree
06-20-2010 06:26 PM
