Help, bike wont start.
I have tried searching through the thread but cant seem to find any related thread on my problem.
On my 05 Electra it doesn't always start. It doesn't always happen but has been happening more and more ofter.
I turn on the ignition and then the start/kill switch and hear the fuel pump run. When I push the start button I can hear what sounds like the starter engaging but it doesn't turn. When I release the start button I can head the shaft of the started retract and make a thump (I think the thump is normal, just don't usually hear it cause the engine should be running at this point).
This could happen whether its been sitting all weekend or when I turn it off for 3 minutes to fill up with gas.
I leave a battery tender hooked up as we have a lot of electronic equipment on this bike such as lights and radios. This bike has about 60k miles on it. The mechanic doesn't seem to know whats wrong with it.
I have tried everything I can think of like connections and such. The battery is showing a good charge on the meter.
Any help would be much appreciated.
I just created a video for this. Hope this helps. Youll have to listen close for the sound it make when I press the button....didnt catch it real well on the video.
http://www.youtube.com/watch?v=xmlQb0axGRo
Thanks again for any help.
Assuming you are getting full battery voltage when closing the start switch, it could be the contact area of your solenoid is corroded, the solenoid is closing, which makes contact between your 'B' or battery terminal and 'C' or starter terminal but the contact is poor. You might get away with cleaning the contact area or install a solenoid repair kit.
Measure the voltage at the starter when you hit the start button. There was a thread earlier about an '03 UC shutting off/not starting. The problem was that the battery lug was crimped over the cable insulation, not bare wire. Had to cut off the shrink tubing to do a visual inspection, but by measuring the voltage on the starter lug you ought to be able to pin point the problem.
Hope this helps.
Hope this helps.
1CdnHD is correct, but you could just have a weak battery. One quick test would be to jump a known good voltage source to your starter. If it spins start lookin' back towards your battery, or jump another battery parallel with yours. If it starts, replace your battery. The trick is to define the problem. Right now it sounds like your solenoid operates but doesn't turn the starter. Either your starter is toast, or you aren't providing enough power through the solenoid. Assuming a good starter I would suspect the battery, but I just fixed a similar problem on my '86 FXR. I had to replace the solenoid, all the circuit breakers, & a battery cable.
There is one thing that you have over looked. Check the ground at the starter. Some think that the chassis ground is enough but it is not. Ask me how I know. It doesn't take much of a turn of the nut but it will make a huge difference. I had to replace my battery because of all the jerking on the cables and applying jumpers. Until one day I happen to be looking at the back of the starter and seen a huge flash of light (ark). It only took about 1/4 of a turn and it was tight and i have not had any problems since.
Try rocking the bike back in forth in gear to make sure that nothing is catching in place or holding the starter solenoid in place. Again check the voltage on the battery, not sure if there is a stater involved before the starter or not. I have had several metric bikes with bad stater and had similar problems, unfortunately never a problem so far with the road king.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
General Inquiries:
Phone:
775.331.3789
