There it is again ......
I'm on my 2nd Harley so I am used to noisy shifting, but I've got an extra clunk that has me a little concerned. First off - '09 Ultra Classic with 9,600 miles, Stage 1, Fuel-Moto slip-ons. I'm used to the shifter clunk, and I actually have learned to depend on the 1st clunk to assure myself that I've actually shifted into another gear, but the 2nd clunk? Not so reassuring. I've discussed this second "clunk" with the dealership - it's normal, don't worry about it - but it doesn't seem right that something should be clunking when you let out the clutch lever after shifting into any gear. I get the loud clunk and the lurch when shifting into 1st after start-up, and it's also very difficult to find neutral - cold, hot or otherwise. I've had all the fluids changed, had the clutch adjusted, no improvement. I understand that Harley transmissions and primarys make noise, it's all part of the "Harley" mistique, but I have to wonder if this is more than just "normal" clunking. I've read the threads on SE compensators but nobody mentions the double-clunking when describing the symptoms of a compensator problem. I don't get the loud "bang" on start-up and I don't get a loud bang when shutting down. Anybody got any ideas what might be causing this?
I've owned it since April 2010, purchased it with the remainder of factory warranty, but no extended warranty, so I am quickly running out of warranty time. I don't know if it has "always" clunked because I just recently took a ride with no helmet (I know, not smart) but never noticed the 2nd clunk while riding with my helmet on. I suppose I could fix it by always riding with a helmet, but I'd rather fix it once and for all.
If I don't give it a little gas as I let the clutch out, I get a "bump", like tapping the brake as the rear wheel forces the engine to speed up. Maybe there's slack in your primary chain and it clunks a little when this happens. Shifting at 2500 rpms and easing the clutch out has solved my jerky shifting.
How many miles are on the bike? I had trouble finding neutral for a while. No problem now.
Check the primary fluid level like bmaier said as I've heard that too much primary fluid can cause it to be hard to find neutral. Possibly other problems as well.
Cecil
Cecil
I guess at $8 a quart, I'll start with checking the primary fluid level. That's a lot cheaper (and easier) than installing an SE compensator. Thanks.
Try this trick that has been around for many decades. Start your bike in neutral while holding the clutch in. Continue to hold the clutch in for about a minute or so. Then shift and ease out the clutch. I can get up to 5 totally silent smooth shifts this way.
While the bike is setting the clutch springs press the oil from between the plates. The attendant clutch drag is what causes the "clunk". Which by the way is not harmful and many like their "clunks".
This is of course assuming that you have checked the the clutch adjustment is set to specs.
Ahhh...that's better!
Drained the primary and put in 38 oz. Formula+. Looked like my Indy may have been a little generous with the Amsoil last time in. Didn't look that much overfilled but maybe that was the problem. Much smoother shifting and waaaaay easier to find neutral. Still getting a slight knock when engaging the clutch so I'll keep after it, but in the meantime thanks for the "you might want to change the fluids every so often" reminder.
