Limited FLHTK: OEM Oil Cooler Swap
Old 04-11-2011 | 01:59 PM
MADHOG's Avatar
MADHOG
Default Limited FLHTK: OEM Oil Cooler Swap
Just curious if anyone with a Limited FLHTK has swapped out the OEM Oil Cooler for an aftermarket one?
I haven’t ridden mine yet during the hot season and I’m not sure if the OEM cooler does the job or not. Of course living out west I do “most” of my riding fall – spring, just get too dang hot here in the summer.
If you have swapped yours out, what is a good product and what kind of results have you had?
Old 04-11-2011 | 02:41 PM
leicafish's Avatar
leicafish
I would not consider it all. In fact the only reason I have one is because it is factory installed. I always look upon these as another faulure point for an oil leak.
In answer to your question the factory on works fine so far. I heat is an issue get a remap or SERT.
Old 04-11-2011 | 03:25 PM
user 8373900's Avatar
user 8373900
The HD cooler is a very good cooler, That would be like removing a chrome cover and replacing it with another.?
Mark
Old 04-11-2011 | 03:31 PM
lp's Avatar
lp
First off an Oil cooler is not going to make your engine run cooler. All it does is cool the oil. The engine is not predominately "oil cooled", it's air cooled. So if you have a hot running engine you need to do something with the fuel-air mixture.
Second, go ride the bike before you change anything... You may find that it runs just fine.
lp
Norms 427
2014-2023 Touring Models
06-26-2015 09:25 AM
Mike Horrell
Oil Archive (no new posts)
04-10-2010 10:48 AM
Mike Horrell
04-09-2010 01:52 PM
tjae
10-25-2008 12:36 PM
electaRICK
07-18-2007 01:10 AM
Quick Reply: Limited FLHTK: OEM Oil Cooler Swap
