Battery Pigtail
Old 10-20-2006 | 11:39 AM
1flhtk4me's Avatar
1flhtk4me
Default RE: Battery Pigtail
ORIGINAL: Tech2
Where is this "factory" pigtail installed? Does it attach to the battery or is it going to the frame ground and another 12v power point, like the fuse block?
Mine is attached directly to the battery,and the pigtail that came with the HD battery tender attaches the same way.
The pigtail that came with my bike is the same as the HD tender I bought.
Old 10-20-2006 | 12:29 PM
petemac's Avatar
petemac
sleepneagle, that's a good idea about routing the pigtail through the split in the seat.
I'm going to hook my pigtail up this weekend and try this.
Old 10-20-2006 | 02:00 PM
MixedNuts's Avatar
MixedNuts
My '05 came with one. Mine comes out through the hole just behind the starter.
If your going to install it yourself make sure the terminals are connected correctly. My positive terminal(battery) is connected so the female terminal(Tender side) is protected by the connector housing. The male terminal is the ground. This way if the connector happens to touch a ground it's not the hot leg.
The pos. terminal has a red marker and the fuse.
Old 10-20-2006 | 02:02 PM
MixedNuts's Avatar
MixedNuts
Tech2...... it connects directly to the battery. Mine exits through the hole just above the starter.
Old 10-20-2006 | 02:24 PM
69z28's Avatar
69z28
My 05 Road King Classic did not come with one, came with the tender and had to install.Very simple though....
Old 10-20-2006 | 03:25 PM
4DZTOY's Avatar
4DZTOY
My '06 RKC came with it. I've noticed they are installed on bikes at all the local dealers around here...I wonder if it's a regional thing....Bikes in areas where they are likely to be laid up for the winter??? Maybe cuts down on battery warranty claims???
My pigtail is larger than others I've seen. It has a small, flat, third terminal....I asked my salesman why it was different...he said something about needing a new kind of charger....All the tenders they had in stock had the usual two prong pig tail....Never did get straight answer what the third terminal was for.... I just plug my tender into the regular terminals and it works fine...
Old 10-22-2006 | 10:59 PM
ricaroo's Avatar
ricaroo
my 06 ultra came with one, and the dealer says he didn't install it. so either I am seeing things or my dealer lied
Harleydawgz
06-27-2013 03:18 PM
bama6977
01-04-2012 11:29 PM
bkg
07-04-2008 08:44 AM
snuffer
12-03-2007 11:26 AM
jonny ebola
10-27-2007 08:00 PM
Quick Reply: Battery Pigtail
