Need CB Help
Need CB Help
I recently bought a used 2006 Ultra Classic 2500 miles. Thought I would add the CB module for sh*ts and giggles as the radio said "Com option not installed see dealer". However I pulled the front fairing only to discover the module is already there and wired in. I have read in past forums it needs to be flashed, others say no just hook it up. I updated the firmware to the latest and that didn't help, pulled the master fuse and waited 15 min plus and no help. I am not the type who likes to run to the dealer, any ideas??
If the bike is an ultra classic it came with the CB radio from the factory. My bike is a 2009 and when I added XM all I did was plug it in and it worked. If you have all the connectors right, I think they will only go one way, then it should work. I think I would take the HD number from the head unit to my dealer and make sure the radio is for the UC. Maybe it has been changed. I believe the number is 76160-06 for the UC. My guess is the CB module is bad or the unit has been changed.
