Help please, exhaust gastet replacement
Can someone please tell me how to replace the exhaust gaskets in the head on my 2010 Ultra Classic. The service manual is no help. The head pipe removal section says, 'remove gaskets, and discard' but doesn't tell you how to remove them. I not into guessing.
Thank you!
Thank you!
Once you disconnect the exhaust pipe and move it out of the way, it should seem pretty obvious on how to remove the gasket.
Sometimes they might get stuck in the channel, so you might need a small pick or flat bladed screwdriver to dig it out.
If you already have the new gasket, you should understand what it is your looking for.
Keep in mind your old gasket will be quite a bit more compressed and the color will make it almost look blended in to the exhaust port.
I too used WD40 also used I think was a 1 1/2" socket to tap in all the way. Needed to be gentle but worked great
Well, the dish washing soap trick didn't help getting the new ones in. Crushed the first one. Got it in there but it has a big hump in it on the inner portion. Well at least I am getting practice taking them out, LOL! Headed to the HD dealer to pick up a few more. The dish soap is plenty slippery enough, probaply more so than WD-40. I was afraid to try WD-40 thinking the paint would come off the motor. Well it came off anyway with the dish soap. Don't know why maybe it is just cooked so bad from the heat that it can't adhere to the aluminum anymore.
The jackpot instructions specifically say to use the tapered OEM gaskets because the head pipe is designed for them. I can't see how the OEM gaskets are going to work though as they are the same outside diameter as the head pipe. Oh, well I'll go get some more and go from there.
trnewman
05-12-2013 10:18 PM
