2000 RPM Decel Chatter...Clatter...WTH???
Old 09-14-2011 | 12:30 PM
Tim Knittig's Avatar
Tim Knittig
Stage II
I have a 07 deluxe with loud snaping / clatter on decel. Also ran leaner and hotter each time noise would appear. Drivabillity was deteriating yet intermitant.some times turning off the ignition and back on would make it reset and run better - some times worse. Found the noise was the fuel injectors were being hammerd by improper signal from ecm. Replaced ecm and runs great and no more noise!
Old 09-14-2011 | 02:29 PM
carlgrover's Avatar
carlgrover
It might be your shift linkage rattling. Bike runs great otherwise right?
I get the same thing on my RKC. It was so bad yesterday I thought I might have to do something about it but today it's hardly clattering at all.
Old 09-14-2011 | 02:37 PM
Tim Knittig
Stage II
Default clatter
Originally Posted by coolerman69
I have a similar problem on my 06 ultra. My noise sounds like a sewing machine when i decel after an extended 80mph + stretch of road. I can tell its high in the engine and i think its the front cyl. My dealer cant seem to duplicate the problem and said just ride it! WTH!
Hi I think its worth checking the electronic controle module. My bike did the same (a hit and miss at the start) but as the the miles added up on the bike, the noise came more regular. It ended up knocking out 3 sets of injectors before I realized it was improper signals from the ecm causing the whole problem. ( the noise was the injectors reacting to the mixed signals)
drivability was slowly getting worse and had head temp topping over 490 deg. Exhaust pipes even glowed red! NASTY HOT! My dealer was not much help, sorry to say, and told me thats normal. I did replace the module with a Thunder Max and it runs great and never again made the noise. Head temp now around 220 deg.
n8bones
08-27-2010 10:59 AM
Cheiron
08-20-2010 12:05 PM
SICKBAGGER
06-16-2010 02:05 PM
scottdoege
05-24-2010 07:31 PM
Puttnutt24
06-12-2009 11:34 AM
