If you are referring to Permatex, then only the copper RTV is for this application.
You may read the specification on the other Permatex products, such as gray, black, red.
The Copper RTV is for motorcycle, and the max temp is 700F
Here is the link: http://www.permatex.com/products/mot...sket_Maker.htm
and Permatex even has a:
Suggested Applications: Exhaust header flanges, slip fit exhaust pipes, and mufflers
In this kind of application, we are making a gasket with an RTV sealant, and the copper has been designed by Permatex for motorcycle to withstand a higher temperature than the others.
I am not expert, but reading has given me this information.
Hope this help.
I have started wrapping the pipe with a thin layer of glass wrap... then slip the tailpipe over the wrap. No mess, no cleanup later and very effective.
That's another interesting method.
By chance, you know what is the characteristics (flexibility, max temp.) of the glass wrap, and where do you get them?
I have to say that the RTV is kind a messy.
Thanks much in advanced for sharing the info.
Nick
