Need Urgent Help = Clutch
Old 04-09-2011 | 10:35 AM
iwillfixthem4u's Avatar
iwillfixthem4u
Originally Posted by Lonewolf176
That sounds like it's not disengaging. Sticky plates when cold can be normal. As long as you aren't running the SE compensator, using atf in the primary can help with this issue. Start the bike in neutral, then put it in gear. Then you will get the infamous clunk.
All of the 2011's come stock with the SE Compensator
Old 04-09-2011 | 10:38 AM
lp's Avatar
lp
As you've finally figured out this is normal and your clutch probably does not need adjusting... well maybe now if you've dicked with it.
All of our bikes lurch forward when you start it and are hard to roll when in gear. "Normal"...
lp
Old 04-09-2011 | 10:41 AM
iwillfixthem4u
also for clarification: the only way to adjust the clutch is inside of the primary as I outlined. adjusting the cable adjusts lever free play not clutch plate clearance. If there is not enough clutch plate clearance this could add to the condition cold when oil is thick .. If I just got the bike I would head back to the dealer on an issue that could be blamed on wear and pilot error.
Old 04-09-2011 | 10:48 AM
103 sedona orange's Avatar
103 sedona orange
Spend $50.00 on a HD Service Manual ,it will be the best $$$ you spend on your bike.
gilbert_roadking
11-15-2016 06:21 PM
All Aces
02-26-2016 08:58 PM
fenwick
02-12-2015 05:50 PM
cnielsen4130
10-15-2006 10:28 PM
COFFESLINGER
06-30-2006 06:35 PM
Quick Reply: Need Urgent Help = Clutch
