Do i need a tune?
Do i need a tune?
New here, take it easy on me.
I have a 2011 RK with about 500 miles on it. I have carriage work slip ons, everything else is stock. If i remove the cat, do i need to retune?
Tommorrow is suppose to 80, today im thinking about removing the cat but I want to make sure I dont hurt it. Then in a couple weeks I will stage 1 it with PC5 and then DYNO.
thanks
thanks
If you just change the slipons, no.....but once you let the Cat out, yes. You need to get a tune or a tuner. The Cat controlls alot of the backpressure, without the tune you will loose a considerable amount of your low to mid-range torque.
You only need to tune your bike if you want it to run at optimum performance.
You loose the venturi effect of the exhaust pulse. The exhaust flow is interupted and has to spread the pressure out evenly against the cat wall. You get your area of flow after the cat absorbs the heat but in turn loose back pressure. It also restricks your sound in a similar matter.
y'all may be rocket scientists, and all that may be the 'correct' answer, but in my case, after i removed the cat, i did not notice any of what you say. time didn't start running backwards and the world did not end. in other words, the ecm did not throw any codes. what did happen, however, was a very dramatic decrease in the amount of heat by my right leg. my performance did not decrease, my mpg did not suffer, the exhaust did sound a whole lot better though, both the stock muffler and the se nightstick.
i ran my bike with the stock ac, cat removed headpipe, and se nightstick, and no additional fuel management for almost a year (13,000 miles) with no problems. i've only just recently added the se ac and powervision tuner, and still loving it!
