Quick Dis-Connect Antenna
Received 49,950 Likes
I've got a shorter version of the "30 Foot Tall" Harley antenna but, to be honest, I never thought about using a rubber washer between the mount and the mast. This works well for you and doesn't seem to cause "major" problems with reception? The rubber wahser keeps it from coming loose ... and that is primarily what I was looking for. Thanks for the tip GMAN1953. My mind isn't quite what it use to be ... of course it never really was exceptional !
Now I just unscrew the one antenna thats in the way.
Why not remove it off the tourpak and keep it off. There were posts in another thread that showed how to mount the antenna sideways inside the fairing. I did this to mine so I could remove the tourpak and not worry about where to put the antenna. I don't use the CB so I just unhooked the cable for the CB and tied it under the side cover. A $2 vacuum cap covers the antenna mounts on the tourpak.
Here's a pic...
Here's a pic...
