Rear fender tail light?
if you include some information about the type of led taillight you're using on which model of bike, it'd be much easier than us guessing what you're dealing with. did you look under the fender to see if any wires were frayed or rubbed by the tire? check with a test light or volt/ohm meter to see if you have power at the socket. that would be the most logical place to start. good luck.
1 Post
My dealer replaced my fender light to the run/brake light free because the guy chipped the chrome trying to remove the lense. There was water seeping in. Anyway, I like it a lot. It's not as bright in the "run" mode and when you apply brakes it realy lights up. Very satisfied with it. The only thing is I should've gone with the smoked one instead of the red.
I know it's a bit of coin, but I can't say enough about having a Bright *** Light behind mine.
harleystu
2014-2023 Touring Models
03-30-2015 03:35 PM
scottt
44
04-08-2014 07:09 PM
