**free** anti security mod !!
**free** anti theft mod !!
My new 2010 FLHTP did not come with HD security. I was looking for a mod that would allow me to walk away with out locking the ignition with the key each time as I was spoiled by my previous traded in bike that had the HD smart security. I realized the start disable gear switch is located on the clutch lever. The clutch lever has extra casting that activates the switch when pulled. My thought is to remove the lever and grind off that piece. This way, I can leave the bike in gear and if someone jumps on to steal her there would be no start even if the clutch lever is pulled in. It is pertinent to leave in gear as in neutral the bike starts without clutch lever pulled.
instead of grinding off anything, why not just use a pre 07 clutch lever? don't you have one lieing around? if not, lots of folks do, you could pick up one cheap.
that way, after you forget and hit the start switch with your bike in gear, after you pick it up, you can change back.
