Headpipe Install Question...???
I'm spending my Sunday replacing the full exhaust system with V&H Dresser Duals, Twin Slash Rounds, and a PCV that I bought from Fuel Moto. I'm at the half way point, as I have just completed removing the entire factory exhaust system.
I just removed the factory exhaust gaskets and wiped down the inside of each port. Now I, of course, intend to replace them with the recommended HD exhaust gaskets (17048-98) that I bought. They are significantly thinner than the factory gaskets. Am I missing something here? Did I do something wrong, or is it OK that they are so much thinner?
Secondly, I remember hearing something about when using the PCV, not having to re-attach the 02 sensors after the new headers are installed. Can somebody please elaborate on this.
With my Fuel Moto head pipe, I ended up doubling up and using two SE gaskets on each pipe to make up the thickness(necessary for the front tube to clear the nosecone). The OEM gasket would squish into the port no matter how carefull I was. Haven't had any problems with the double stack SE gaskets.
Oh snap.....I didn't even notice that the factory gaskets were tapered. But it sounds like I'm good to go then with using the new SE gaskets. I just wanted to make sure before I used something wrong and had to remove it all to fix the mistake. Thanks. Can you or anybody else educate me on my other question about the O2 sensors?
And what do I do with the 02 sensors? Maybe just zip tie them snug to the frame?
When my pipes arrived (D&D Fatcat), they came with 02 bung plugs in them that I had to remove to install the 02 sensors.
