What did you do to your bagger today?
Old 03-15-2020, 09:26 PM
rcrankin's Avatar
rcrankin
rcrankin is offline
Got tired of being cooped up. Went to the garage and washed the bike. The paint looked dull, so I got out my Griots investment and got to work. For a first timer, I impressed myself. 90% of swirls, scuffs and scratches are gone and I didn't fu@k up the finish. I'll go after the 10% in a few months.
Rob
  #14442
Old 03-15-2020, 11:36 PM
UrbanRunner's Avatar
UrbanRunner
UrbanRunner is offline
Veteran: Marine Corp
Not today, but Friday night, installed a replacement Bung King shift linkage:
  #14443
Old 03-16-2020, 08:14 AM
Superdog3:16's Avatar
Superdog3:16
Superdog3:16 is offline
Rob
Pix????
  #14444
Old 03-16-2020, 08:22 AM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
Originally Posted by dirtdreamer50
SNOW??? 81* here today, but worked and mowed the grass... Ear plugs are a wise move. Hope the tune does good things for you. tp
Ah Ha ............ So you're the one ................. Now it's gonna rain all week according to the forecast. Gah ..........
The following 2 users liked this post by MikeyTX:
Captain Glide (03-16-2020), dirtdreamer50 (03-16-2020)
  #14445
Old 03-17-2020, 12:18 AM
rcrankin's Avatar
rcrankin
rcrankin is offline
Originally Posted by Superdog3:16
Pix????
I'll see what I can do. Lighting in the garage isn't the best and its supposed to be overcast this week.
Rob
  #14446
Old 03-17-2020, 12:42 PM
Earthbound's Avatar
Earthbound
Earthbound is offline
Brought into shop today for 1,000 mile oil change and stage 1. As part of the sale, was able to get windshield, back rest and Eliminator 400’s. Road the bike for a week before install and swear I feel a slight decrease in torque with the slip on’s. Maybe just used to the speed now. Anyway, figured I’d do the air cleaner and have Harley tune with sepst. Not looking for anything more than smoother, more throttle response and my torque back. I pick up in a few hours. Fingers crossed
The following 2 users liked this post by Earthbound:
Bafflingbs (03-25-2020), Pirate6 (03-17-2020)
  #14447
Old 03-17-2020, 02:07 PM
DynaKid94's Avatar
DynaKid94
DynaKid94 is offline
Rode it to work against the wishes of Komrade Newsom. Didn't buy this thing for it to sit and look pretty in the garage. And I wanted to try out my new Bell Eliminator helmet, liking it so far...
  #14448
Old 03-17-2020, 04:53 PM
Pirate6's Avatar
Pirate6
Pirate6 is offline
6th Gear
with less back pressure you will notice less low end torque. Upper end throttle response should be better. After your tune you should notice more differences.
  #14449
Old 03-18-2020, 10:25 PM
Bobster109's Avatar
Bobster109
Bobster109 is offline
Added a bigger "rear" bag!
  #14450
Old 03-19-2020, 05:39 AM
FrankEV's Avatar
FrankEV
FrankEV is offline
Default Learned a valuble lesson the hard way
I keep my bikes on a battery tenders whenever parked. The tender for the SGS is located in a storage cabinet next to where I park the bike and out of direct sight. Last Saturday with the bike in its normal parked location with the bike plugged into the tender I was doing some maintenance work on the wiring under the seat after the the new Air Ride system had been installed and I had the ignition turned on and off frequently over a number of hours.
I was heading out with my son for a ride Sunday morning only to find the battery was dead. Unknown to me, because I did not check, we found the battery tender itself was not pushed all the way into the 110 volt outlet and it had not been charging. Here is the nightmare that followed.
In an atttemp to jump start the bike we tried to use the bikes battery tender leads with one of those jump packs. When doing so the leads got very hot and both sets of micro switches in the ignition dash panels were fried blowing the P&A 20 Amp Fuse. It took all morning, a lot of 20 A fuses and a lot of research to diagnose what had happened. It then took a trip to two different H-D dealers amd about $140 to get the two needed switch packs. Our research found that I am not the first one to try this way of jump starting a bike only to cause the same damage...an anoying time consuming and costly lesson.
After installing the switch packs and putting the bike back together, we were ablle to jump start the bike correctly using a regular boost battery charger connected directly to the bikes battery. We did a short ride that evening to make sure all was OK. We got to ride together on Monday and Tuesday without any problems before he had to head back home to NC yesterday.
I know this has been discussed elsewhere in this H-D Forum before, but I felt it would not hurt to post this up again for the newer bike owners that may be reading these posts. Hopefully it might prevent others from making the same silly mistake.
The following 2 users liked this post by FrankEV:
Odd986 (03-19-2020), ridingalong (03-25-2020)
Quick Reply: What did you do to your bagger today?
