What did you do to your bagger today?
Old 02-24-2019, 05:34 PM
Essthreetee's Avatar
Essthreetee
Essthreetee is offline
Changed Primary and Trans oil.
Switched to Red Line VTwin Primary and Red Line VTwin Transmission fluids.
The shifting seemed much smoother and way easier into Neutral.
  #13192
NWTruck's Avatar
NWTruck
NWTruck is offline
Nice job !
  #13193
Old 02-24-2019, 06:14 PM
Zedbra's Avatar
Zedbra
Zedbra is offline
One of our dealers was hosting a swap meet today so I loaded up my sons and drove the 60 miles to check it out; seemed like the right thing to do on a winter day. I was hoping to spot a new pulley, but no luck. I did find a new Evo horn cover that I figured I could do something with on my TC, as I really didn't like the huge air horn my bike came with - it had to go. Managed to sneak a Fiamm car horn into the cover then use the old bracket from my air horn to mount the horn and my bottle opener - for emergency situations, of course. Test fit the tank and there's just enough room to make this all work.
  #13194
Old 02-24-2019, 08:36 PM
1LargeDog's Avatar
1LargeDog
1LargeDog is offline
Did something similar with the DK. Routed the lines to the bottom of the stock cover, drilled a hole and mounted the filter underneath. Also used a K/N filter.
The following 2 users liked this post by 1LargeDog:
Odd986 (02-24-2019), Zedbra (02-24-2019)
  #13195
Old 02-24-2019, 09:27 PM
Odd986's Avatar
Odd986
Odd986 is offline
I didn't want the filter to show. It doesn't look bad on yours but I think my bright blue filter would stand out.
Do you get much oil in your filter?
  #13196
Old 02-24-2019, 10:02 PM
1LargeDog's Avatar
1LargeDog
So far, no oil.
  #13197
Old 02-24-2019, 11:14 PM
rubberguy's Avatar
rubberguy
rubberguy is offline
ODD986, I don't think there will ever be enough pressure on the hose to blow-by oil up and along the backbone. this is why they always exit towards the bottom.
  #13198
Old 02-25-2019, 07:14 AM
Odd986's Avatar
Odd986
Odd986 is offline
I'll have to keep an eye on it when it finally warms up and dries out enough to ride. I went up after seeing that Kevin from DK Custom's Heritage has the breather bolts going up.
  #13199
Old 02-25-2019, 09:45 AM
hbsoldier3's Avatar
hbsoldier3
hbsoldier3 is offline
Originally Posted by Odd986
I still have the stock air box, so due to the state of the Canadian dollar I thought I've give it a go at making my own external breather system. DK Custom sells kits and when I go to a different air cleaner I'll need to get one of their set ups.
3' of 7/32 vac/washer rubber tubing, 1 k&n 62-1600bl air filter, 1 "T" fitting and 1 3/8-1/4 barbed union.
$28.67 after taxes
I liked the idea of having the hose coming out the top versus the bottom. The hose runs along the back bone to just infront of the battery. I have DK's 2" deluxe tank lift which gave me enough clearance for the hose. There is a grove under the rear tank mount on both sides the right side is in use but I had room on the left side. There might be enough room without the tank lift not sure.
I used two short pieces of the 7/32 hose filled with silicon to fill the holes in the back of the filter.
Air filter reinstalled.
Picture of filter location.
Now to wait for warmer days to see how it works.
I like your idea, but how do you get the oil and water and mist to go up the tube? In addition, I would not put a filter in the the battery compartment. I do not use a filter at all, just run the line down under the frame. These are just my opinions, not trying to sound like an ***.
  #13200
Old 02-25-2019, 01:09 PM
Odd986's Avatar
Odd986
Odd986 is offline
hbsoldier3 thanks for your in put. Acording to Kevin from DK Customs as long as the bike is run long enough after reaching operating temp, not all short trips there shoulbn't be a problem. I'll still have to check after riding season starts. The filter is in an open space in front of the battery box not actually in with the battery.
hbsoldier3 (02-25-2019)
Quick Reply: What did you do to your bagger today?
