What did you do to your bagger today?
Old 05-03-2018, 09:39 PM
GittinThere's Avatar
GittinThere
GittinThere is offline
Can't wait to take 'er for a spin to feeeel all that extra power! Less friction from wind flowing across that chrome rather than the black rubber surface - might be closer to 10 more HP 😜
  #12012
Old 05-04-2018, 07:39 AM
Mrfixitman's Avatar
Mrfixitman
Mrfixitman is offline
3rd Gear
I am having trouble with my 2009 Ultra Classic cruise. I added the turn signal extensions from HD and now my cruise won't engage. I have looked for wiring problems on the switches on the handle bars all looks OK, Also after installing the switch I found I had to move the throttle twist up to allow it to engage. All front and rear break switches work correctly and not keeping break light on, I need some helpful suggestions. I went thru the throttle idle reset instructions but the red cruise icon never turns GREEN??
  #12013
Old 05-04-2018, 11:35 AM
Angryman's Avatar
Angryman
Angryman is offline
Originally Posted by dirtdreamer50
Found that they do bleed down over time... Should be OK this season. Check the lbs every week or two, to keep the ride the same over time. tp
Well checked the air pressure again today and was at zero. Looks like I need new rear shocks. Anyone have a line on a good deal on some take offs?
  #12014
Old 05-04-2018, 12:08 PM
head's Avatar
head
head is offline
I still think that it is your hand air pump that is releasing the air out of the system. You have to use a no loss air pump on these. If you hear any air at all when you unhook the pump, it is losing the air. Now on a tire holding 30 pounds of pressure, when you hear air at the valve stem after filling, that's no big deal. But on these shocks, the system is so small that it will lose all the air if not using a no loss air pump. Harley makes the proper tool to check and fill them and also there are aftermarket ones as well. IF the shocks are leaking, it's usually an easy fix...make sure lines are pushed in properly at the connections....take brass fittings out of the shocks and re-apply teflon tape. Hope this helps.
Head
  #12015
Old 05-04-2018, 12:29 PM
Angryman's Avatar
Angryman
Angryman is offline
Head
I will give that a try and hope you are right. I am leaning towards they are bad because last year when I got the bike I checked them and noticed they needed some air. I added some using my air compressor not realizing you are not supposed to do that.
  #12016
Old 05-04-2018, 01:58 PM
sailmotion's Avatar
sailmotion
sailmotion is offline
Received 7,846 Likes on 3,238 Posts
That's a critical piece of info. I'm guessing you blew a seal. Not this kind:
  #12017
Old 05-04-2018, 02:43 PM
Angryman's Avatar
Angryman
Angryman is offline
Yeah I figured they were done for. That's funny
  #12018
Old 05-04-2018, 07:40 PM
18glide's Avatar
18glide
18glide is offline
Installed color matched front air intake and rear tour pack spoiler with brake light
  #12019
Old 05-04-2018, 08:33 PM
RickW3's Avatar
RickW3
RickW3 is offline
Modded my stock air cleaner (cut out to just a round cover) and installed with a tri bar spinner. Also added my fork lock cover. No just need some time to ride.
  #12020
Old 05-05-2018, 05:56 AM
RFG7680's Avatar
RFG7680
RFG7680 is offline
Received 1,280 Likes on 733 Posts
Installed the rear Defiance boards.
Quick Reply: What did you do to your bagger today?
