Just picked up new 2011 SG - Very Frustrated
#41
I was not aware any dealers were installing these.
#43
Tony, simple enough to have the dealer use digital tech or sert to check TP, IAC steps, could be as simple as a throttle blade adjustment or a redo of the free air calibration, even though my ems had the tape over adjustment pods, one was flashing and the other solid on, so I took the extra couple of minutes to do it. Either way, Rev Perf has shown exceptional customer service with any questions I have had, before and after purchasing them.
#44
#45
#47
you got an exhaust system, S.E. air cleaner, cams and tuner. didn't they dyno it to make sure that your recipe would work? i'd think that after they installed the mods they would have taken it out to see if everything was working properly. ride it back to the shop and let them make it right.
#48
#50
you don't know its the tuner, it might be tuner installer that is problem, I have not heard of one problem with it, most likely an installation issue, or they didn't do start up procedure correctly, but yea they (the dealer) needs to get it right, what are they doing delivering a bike that doesn't run properly? if they can't get it right, they should not release the bike!! don't worry about a doctor, my laywer knows a good one!! some shop managers have their heads right up their asses!!
