how about this switch for the garage door mod?
looks like a nice momentary switch to me, anyone have any experience with it? switch and the rubber boot
Here's the part number for the odometer switch, 67854-98. Its like 12 bucks and the boot will get another 2 bucks from ya.
http://partsfinder.onlinemicrofiche....=13&A=599&B=61
Just tie into the high beam switch, then you wont have to remove your hand off the bars, Cost 0.00
I connected mine right at the head lamp plug. Just opened the back of the connector and soldiered my wire on and closed the connector after finished.
Jim
Jim
Here is the one I ordered. $3.95 with the rubber cover.
Little Pushbutton Momentary Switch (5A) Tall
Small push button momentary ON switch with rubber cover and 12cm (4 1/2") leads. Leads are 4.5" (11.5 cm).
Fits in a 3/8" (9 mm) hole.
NOTE: This switch will fit panels up to 5mm in thickness.
It is about the third or fourth product down.
http://www.easternbeaver.com/Main/El.../switches.html
They have both momentary and on / off. Make sure you get the momentary for the garage door mod.
