Want to go with Bagger HOGPRO 'Wide Drive Kit 2007-2008' on a 2004
Hey, Has anyone installed a Hogpro bagger 'Wide Drive Kit 2007-2008' on a 2004 bagger (RKC)? I think the only change in 2007 was the six speed trans, but the wheels remained the same size i.e., rear tire MT85-B16, so wondering if anyone actually made it work for the older baggers.
What i would like is the 5.5" rear rim and 180 tire/fender setup and Hogpro has the 2007-2008 kit that doesn't require the secondary pulley change.
I had my eye on the Klock Works 180 Mo' Tire kit, but they say you can put the 180 tire on a 5.5" rim and use the stock swing arm, but you would have to change to their narrower pulleys.
I would install myself, so looking for input. Thanks
