I replaced the original shocks on my Road King with Profile Low Touring Shocks and they were great. However, I am selling the Road King and want to keep the low touring shocks, so I removed them and put back the original shocks. The problem is they will not build up any air pressure. I used my HD air pump with no luck. I then tried a bicycle air pump and still no air pressure in the shocks. I did read in the service manual that the shocks should not be laid down, which my were while in storage. Do I need to replace these? Thanks.
When I put my shocks on, I was trying to insert the airline into the shock fitting with the little connector thing pushed in, and then was trying to pull the connector out with the line inserted. I couldn't get them to pump up, and I realized I was doing it wrong. Make sure the connectors on the shocks are pulled "out" and then simply insert the airlines. Hope that helps.
Reason: Said it wrong the first time.
On laying them down, shouldn't affect air pressure. Could have caused oil to leak out, which would be a different issue. But they would still hold pressure.
O.K. and thanks for all the help. I will cut 1/4" off the end of the tubes, and make sure they are inserted properly. I'll let you all know how I made out.
Bill
